Can you use Use create user event, generate user event, etc. to pass data from one VI to another VI, kind of like global variable? Is it possible?
Accepted by GRCK5000
@GRCK5000 wrote:
Most programmers advise not to pass data between two or more VIs using global variables. I had a post some time ago and I asked if it was possible to pass data between two VIs and @mcDuff said that it was possible and even provided great examples. In these examples, events are being used to pass data between two loops, more like producer-consumer architecture, but not between VIs.
I have attached a VI called sender and I would like to pass string "hello" to receiver.vi
You could use a named Queue, although caution is needed when using them.
The following example will work, if and only if, your receiver VI is started before the sender.
Message 11 of 14
(221 Views)
I use them all the time - did you know, you can spawn up to 1Billion named queues on  2014 intel I7 @ 12 gb ram before running in any problems?!  (labview reports a warning or error too many queues, if I remember correctly)
and you are meant to close them, by "close queue"
probably, no good advice...
Message 12 of 14
(210 Views)
Named Queues, Bytes at Port, Global Variables, etc. are like religion and politics on this forum; don't want to get into a flame war, thus a warning. 🙂
PS I use them too.
Message 13 of 14
(205 Views)
Thanks McDuff! I will definitely go with queue, just turn the two codes into subVIs. Boom!
Message 14 of 14
(189 Views)
