05-23-2013 05:58 AM
Hello
I am using LabVIEW drivers for Pickering precision resistor card to set the resistance programatically.
I have attached the VI. I am able to set the resistance and the program does not give any errors. I am able to close manually the front panel and block diagram of the VI.
But I cannot close LabVIEW after that. LabVIEW hangs.Please let me know what can be the reason for this.
05-23-2013 06:18 AM
Can you attach remaining VIs specially pipx40 close.vi
05-23-2013 07:54 AM
I think your best bet is to fire an email off to pickering support, they are normally good at getting back to you.
