05-14-2012 05:55 AM
Can a case be created for Case Structures of a decimal value or range? That is say 0.001..0.5?
I can create case structure for say 1..5
can I create it for 0.001..0.5?
05-14-2012 06:03 AM
No you can't, the case structure terminal doesn't support decimals. but if you have a hand full of range like [.001;.01[, [.01;.1[ and [.1;.5[ then you could multiply and round the value by 1000 and set your range to 1..10, 10..100 and 100 to 500.
Just a quick idea, other solutions would be possible.
Epictetus
05-14-2012 06:39 AM
Thank you so much.
05-14-2012 06:41 AM
you're welcome 🙂
Epictetus
