Case structure with timing control
Hello All,
Currently i am controlling my pressure manually as if i have to change the case structure 0, 1,2 ,3,4 whatever case i want. But i want it to controlled like timings. if i want to run first case for 30sec and other for 30 and so on.
I am attaching my file.
Please help me out.
Siddharth
Message 1 of 12
(4,209 Views)
I never seen feedback nodes outside of a While loop connected to Shift Registers before! 😄
What is the purpose? It just does not make sense to me... (edit: i put the snippet below so others can help easier even if they do not have LV).
About your actual question: search for the term "State Machine". A state machine could serve your requirements easily.
Message 2 of 12
(4,195 Views)
hi sidring,
please remove the FeedbackNodes!
Initialize the ShiftRegisters before the WhileLoop with the correct data type.
(shift registers and feedback nodes essentially serve the same purpose,
but what you've done means, after the whileloop finishes the values are kept and would be (not in your case, because there is no outer loop) fed back into the loop)
regarding your problem:
if it is clear, what kind of action you want to take at a given step,
then you can put them all in line with waits in between, or make a loop that does the same (and the case is the current iteration#) with wait.
for complexer setups the suggested state machines or producer-consumer design pattern would be best.
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 3 of 12
(4,161 Views)
Unfortunately, I cannot open your VI on my PC.
But if I understand your question correctly, you need when you reach the case 1 for example, that the program waits 30s before it jumps to the next case.
So, in this case:
-           a state machine is appropriate for this purpose
Please read the following link:
http://www.ni.com/tutorial/7595/en/
  Here you will find some very good examples on Shift Registers:
http://www.ni.com/getting-started/labview-basics/shift-registers
Afterall you can judge if it is useful to use the feedbacks in the WhileLoop.
Maybe you can try with and without to see?
Furthermore:
-           “Case control” of type INTEGER is more appropriate.
Hope it helps you a step further. And don’t forget to give the KUDO 😉
Kind Regards,
James.
Greetings and Regards,
James
Message 4 of 12
(4,155 Views)
The feedback nodes accomplish nothing there.  If they are removed and the shift registers are left uninitialized, the behavior would be the same.
Message 5 of 12
(4,130 Views)
Thanks for pointing out my mistake but how to use the state machine for timed case structures.
Message 6 of 12
(4,128 Views)
This question sounds familiar.  Are these questions related (from the same homework assignment...different students)?
aputman
Message 7 of 12
(4,104 Views)
Personally I would prefer producer/consumer for timed events
Message 8 of 12
(4,097 Views)
Hello sidring,
a simple example
best regards
Alexander
Message 9 of 12
(4,069 Views)
Hello I have a simple problem. How can I control a Boolean variable changing its value when I press a button. In general I want a Boolean to be false in default , I press a button and it becomes true for a specific time (I want to be able to change this. Value from a numeric control ) when time passes Boolean returns to the default value .
Thank you
Message 10 of 12
(3,417 Views)
