Change block diagram background color
I need help... I'm refactoring a set of .vi and for some reason I found them having a weird green background.
Besides aesthetics I have some functional problems... blocks border are nearly not-visible and also logic value wires.
I tried to change it trough Tools->Options->Environment but:
nothing changes.
BTW if I add a new sequence the background is correctly set to white/light gray....
Thnx in advance to anyone !
 Mike
Message 1 of 9
(586 Views)
Accepted by topic author michele.santucci
Select color brush with shift right click and then right click to change background color.
Message 2 of 9
(580 Views)
Thnx ! You saved my eyes' retina !
Message 3 of 9
(569 Views)
I have a couple of times used it with good result, using a very discrete color to differentiate between a couple of loops, but it should be used very carefully and sparingly.
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 9
(545 Views)
My eyes prefer green to white - but lighter than that.
Another possible use of BD coloring is when you compare two different versions of a vi. Obviously if you don't want to use the Compare tool.
Paolo
Message 5 of 9
(532 Views)
It looks a bit like the old OpenG color. However as a background it definitely is to strong!
Rolf Kalbermatter
My Blog
Message 6 of 9
(523 Views)
I recently have adopted the idea from Hunter Smith of alternating between white and an off-white for the backgrounds of structures. I do find it helps. The off-white I am using is 240, 240, 240. It is just enough to be able to notice a difference. Of course, I have this as part of my VI cleanup plugin.
GCentral
Message 7 of 9
(515 Views)
Yes, something like that. 🙂
Qestit Systems
Message 8 of 9
(503 Views)
I do the same.  It really does help keep nested structures better defined and easier to navigate.  I stick with light shades of grey though.  I used to work with a LabVIEW guru that was color blind, and used the most garish colors in his code so he could see the difference.  Almost made my eyes bleed. 😱
Message 9 of 9
(453 Views)
