Change the loop incremental sens
I just would like to change the loop incremental sens.
Please let me know if you have an idea  how to do it.
Message 1 of 10
(733 Views)
Hi jul,
What is the "loop incremental sens"?
When you want to scale the iterator value of a loop: apply simple math on the "i" value of your loop!
Message 2 of 10
(724 Views)
I tried to do it bu it doesnt work with the incrementation
Message 3 of 10
(692 Views)
the incrementation sens means rather have in 1, 2, 3 i want to have 4->3->2->...
Message 4 of 10
(689 Views)
Post your code and possibly explain in more detail what you want to achieve.
Paolo
Message 5 of 10
(688 Views)
In order to change the excel cell positinning i control it with the number of the raw and the column
but for one condition i have to go back up for the raw selection
so i decided to use it with a incrementatio loop
However i need to change the incrementation loop
like i previously explained
Message 6 of 10
(685 Views)
First, we can't debug pictures. Second, you picture is completely useless since does not show how the row and column indexes are calculated.
(Third, try to avoid waisting all that block diagram space).
Paolo
Message 7 of 10
(672 Views)
first, i cant share the vi is confidential
second, this incrementation is a numbering for a rate i command
Message 8 of 10
(667 Views)
Accepted by topic author jul65651651
Hi jul,
There is no way to natively change how "i" increments. It will always start at 0 and end at N-1, N being the total number of iterations.
If you want another index sequence, you have to do it yourself using simple maths (As @ explained):
Raphaël.
Message 9 of 10
(649 Views)
Thank you
Message 10 of 10
(639 Views)
