Cheap tablet for labview?
I am looking for a tablet that can run labVIEW. Is there any cheap tablets that is compatible with labview?
I know that microsoft surface pro 2 can run it, but its way to expensive.
-Adam
Message 1 of 11
(4,621 Views)
surface pro 1 run about $450 for a refurb at the time of posting.
Message 2 of 11
(4,498 Views)
How would you wire with it?
Bill
CLD
(Mid-Level minion.)
Message 3 of 11
(4,479 Views)
why would you be wiring with it any different then a laptop running Labview. Just use the usb for any NI usb daq. I'm using it with a myrio and wirelessly have them linked.
Message 4 of 11
(4,469 Views)
I dunno.  Why would you need a tablet if your're going to use a mouse?
Haha - I think we got our wires crossed (pun intended).
I thought you were going to use it in a DEVELOPMENT environment.  Silly me.
And of course, since you were thinking about applications, you thought I meant wired vs wireless network.  Nice.  Sorry about that.
Bill
CLD
(Mid-Level minion.)
Message 5 of 11
(4,464 Views)
Accepted by Adamgot
Hi Adamgot,
Perhaps you have already found a suitable tablet? Otherwise I recommend comparing the LabVIEW system requirements with available Windows tablets. As stated in a prevous post, there are som models available from ~400-500 USD.
Robert P-F
Applications Engineer
Message 6 of 11
(4,413 Views)
Thanks for the responses. I ended up with windows surface 2, not the cheapest, but can be used in a development enviroment. Because of windows 8.1 (not rt). Will use it to transfer ecg signal with bluetooth.
Message 7 of 11
(4,404 Views)
Adam, did you mean to say you got a Surface Pro 2? The Surface 2 is Windows RT.
I need a tablet for end users to run LV executable and acquire data over Bluetooth. I am doing the development on a standard Windows 7 computer and LV 8.5.
Any thoughts?
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
Message 8 of 11
(4,300 Views)
Hello. Yes it was the surface PRO! I aquired data using bluetooth SPP and VISA functions. Works really well.
Message 9 of 11
(4,278 Views)
Is it possible to use  a Microsoft Surface 3 tablet support for DAQmx devices?
Message 10 of 11
(4,182 Views)
