Check if File or Folder exists Issue
I have observed a strange issue with "Check if File or Folder exists". It says file exists even if the string is empty.
AB
Kudos are Accepted
(5,407 Views)
Actually Empty path refers to the mapped drives in the computer. You can check the detailed help for the same.
For the same you should use "<Not a Path>" instead of empty if you are not intended to input a path.
(5,389 Views)
Use Empty path check before checking for Path exists
(5,380 Views)
Accepted by AB@17
(5,378 Views)
The VI itself has the check internally
AB
Kudos are Accepted
(5,367 Views)
