07-08-2015 11:18 AM
I created a class in LabVIEW 2014, then added a VI for Data Member Access; Static Dispatch, & Dynamic Dispatch Template.
I'm just using the default ICON. All of these VI's have terminals connected by default to the class instance and error (In & out).
I can connect up to these VI's, but when I right click and select "Visible Items/Terminals", the VI disappears. It's still there on the screen, but I can't see it. If I turn the label on, I can then locate it.
Seems like a good way to cause some real nasty debugging problems (an invisible code segment).
What's special about the Static/Dynamic dispatch template VI's that they can be made invisible? ...and why would you want to allow this?
Note: I'm currently using a trial version of LabVIEW 2014.
07-08-2015 04:15 PM - edited 07-08-2015 04:18 PM
Since it's the trial version of LabVIEW, you can only try to look at the VIs, but they won't let you. Nah, just kidding!
Can you share the VI you're having trouble with? Maybe the VI has no pattern set for the terminals, so it's not actually invisible it's just one big terminal.
Re-read that you have error clusters and stuff wired. I use dynamic dispatch VIs and VIs from the data member access template all the time and haven't seen this before.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
07-08-2015 06:37 PM
I'll try it again after I reactivate my subscription. Then if I have the same issue, I'll contact NI support and ask them about it.
Thanks.
07-09-2015 07:17 AM
Cheers
07-09-2015 06:51 PM
Hi PointOnePa,
I was able to replicate what you were experiencing. However, if you hover over the VI from Static Dispatch Template or VI from Dynamic Dispatch Template the terminals are highlighted. I definitely understand your debugging concerns. I am looking into this further to see if this is expected behavior or not.
Either way, thanks for bringing it to attention!
07-09-2015 07:19 PM
Seems like a good way to cause someone a headache if they can't find an invisibile VI.
