Clear Text of "write buffer" When i Press Enter ?
hi Smiley Very Happy
how can i Clear Text of "write buffer" When i Press Enter ?
Message 1 of 8
(4,126 Views)
hi
       send me the more details or example code what your try...
Message 2 of 8
(4,095 Views)
Assuming "write buffer" is a control on your front panel, you will need an event structure to capture the value change event of the "write buffer" and do whatever it is you need to with that value.  Also in that event case, use a local variable to write an empty string to the control.
GCentral
Message 3 of 8
(4,083 Views)
THANKS MY Friend
I FIND answer  Smiley Very Happy
http://s6.picofile.com/file/8243012718/1.png
Message 4 of 8
(4,069 Views)
No.  Do NOT use the Value property for this.  Use a local variable.  The property node is 1000s times slower than the local variable.
GCentral
Message 5 of 8
(4,057 Views)
hi crossrulz,
IF use local variable can't able to controll the data flow.than why your say use local variable..
Message 6 of 8
(3,978 Views)
Hi Gokul,
in the image the DATAFLOW is (apparently) enforced using a flat sequence.
So why waste precious CPU time for thread switches by calling a property node when a local variable will give the same result in less time?
Message 7 of 8
(3,960 Views)
A property node does not follow data flow either.  It introduces the exact same race conditions as a local variable, but it horribly slower.
GCentral
Message 8 of 8
(3,931 Views)
