Clear shift register before running VI again
I have this very simple VI that read voltage from a DAQ until I stop the loop, it then saves the data into a .wav file.
My problem is: everytime I stop the VI, I would expect the shift register to clear. But if I restart the VI it saves the old data from the shift register and the new data into the .wav file. I just want the new data when I run the .VI, without having to close the program everytime.
Please help.
Message 1 of 13
(8,344 Views)
Pop-up on the SR and create a constant.
Ben
Message 2 of 13
(8,338 Views)
Hi, I tried doing that with a zero constant, but it causes a bunch of broken wires since the wire type is dynamic, but the constant is not.
Message 3 of 13
(8,327 Views)
We I'll be... !
I never use the dynamic data type so  I can only offer a possible work-around.
Cntrl-copy the the Waveform Graph 2.
Right-click and select "Change to Constant"
Wire that newly created constant to the outside of the SR.
Does that work?
Ben
Message 4 of 13
(8,320 Views)
That allows me to create a constant(a very weird looking one), but it does not clear the shift register.
Message 5 of 13
(8,312 Views)
Accepted by Gear
right click the array control and choose "clear array" (or whatever tht option os called) and try it again. that is a cluster of an array of waveform data types. You can right-click (afterwards) and choose "view as icon".
Ben
Message 6 of 13
(8,305 Views)
Accepted by Gear
When you use that method to create a constant, it keeps the data from the control that it originated from.
Right click on the edge of the array constant until you see an option that says "Data Operations" > "Empty Array".
That should clear it out.
EDIT: oops, Ben posted the same thing while I was typing.
Message 7 of 13
(8,303 Views)
You need to initialize the shift register. The best way I've found to do that with dynamic data is to use a conversion to a blank array constant. See the attached screen capture
Message 8 of 13
(8,297 Views)
Perfect!! But the name was "delete element"! Great idea with the "replace" option!!
Message 9 of 13
(8,294 Views)
Perfect!! But the name was "delete element"! Thank you
Message 10 of 13
(8,293 Views)
