Click a button to show/hide a text
Hi all,
I'd like to create a HELP button. It means when I run the labview, just need to click that button then It will show a text I wrote before. Click again to hide the text.
Is there any Vi to do this?
Thank you in advance!
(4,361 Views)
dialog and User Interface >>> Help
VIs there will let you control the help window and hide show help included with cotrols and indicators.
Ben
(4,354 Views)
Accepted by lucbk
There is no readymade VI available for this .You can use visible property.
This is my idea
1. First create boolean control
2. Create string indicator (to show string)
3. When user press boolean control make string visible(need to use visible property) and vice versa.
(4,351 Views)
Thank you Ben. Let me try in Dialog and User Interface
(4,343 Views)
 PiZviz
Great. Thank you, I will try 🙂
(4,342 Views)
