Code for vending machine
Sir,
     I would like know the code for a vending machine which has x no of items and accepts any change and at the same time returns the excess change back to the customer.
           Thanking sir.
Message 1 of 21
(12,244 Views)
Accepted by vendingmachine
State Machine.
Are you looking for somebody to just do this for you?  Or are you just stuck somewhere?  What have you tried?
GCentral
Message 2 of 21
(12,238 Views)
if code is readily available i will go through it and try it
@crossrulz wrote:
State Machine.
Message 3 of 21
(12,233 Views)
i tried a vending machine which does not give change and acpets only the exact chnge so i would like to modify it if someone guides me
Message 4 of 21
(12,230 Views)
It doesn't seem like your problem is really solved.  So you might want to unmark my earlier post as the solution and give me a Kudos instead.
Care to share your code?  Tell us where you are stuck.
GCentral
Message 5 of 21
(12,221 Views)
Are you doing this as practice for the CLD? If so you may want to spend time figuring it out on your own since there will not be anyone who can assist on the exam itself.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 21
(12,216 Views)
could kindly assist me with the code
Message 7 of 21
(12,206 Views)
no am not preparing for cld am at the basic level trying to learn labview
Message 8 of 21
(12,204 Views)
You need to show us some code so we know where you are at.
GCentral
Message 9 of 21
(12,192 Views)
If you understand the existing code, it should be trivial to make these changes. Do you understand the code you currently have?
If you show us the original code, maybe we can give you some pointers.
Message 10 of 21
(12,192 Views)
