11-29-2012 09:54 AM - last edited on 03-15-2024 03:29 PM by Content Cleaner
@Kniswonger wrote:
I found this example program, would it be applicable to what I'm trying to do? https://forums.ni.com/t5/Example-Code/Using-TCP-Functions-to-Connect-to-a-HTTP-Server-in-LabVIEW/ta-...
By typing in the IP address in a web browser, I'm able to see Eaton's software and view/change all of the registers. What I want to do is find a way to write those values into an excel spreadsheet. Could I do that with the VI on the attached link?
There are shipped examples with LabVIEW on reading/writing to Excel.
12-03-2012 08:59 AM
One last question...I'm going to just purchase Labview Full so that I can have access to tech support and all of the training documents. NI seems to think I'll need the DSC add-on for what I'm doing with it. But I don't think the Eaton module is truly a PLC. Do I really need the add-on to get this system to work properly?
12-03-2012 09:40 AM
The DSC module has Modbus TCP support built-in, and I would imagine is a well refined solution compared to the modbus library. If you don't want to spend a lot of time trying to figure out the protocol, then it may be a good investment for you. But, if you want to do the protocol yourself, you have no need for it.
12-03-2012 09:44 AM - edited 12-03-2012 09:44 AM
Thanks Matthew, looks like I'll try to convince my company to purchase it as well as the Labview software. Hopefully it will be easier to work with!
