Communication error USB7855R
Hello everyone,
I am now using the USB 7855R FPGA again after a longer break and I am getting an error about the communication between host computer and the FPGA target:
I am using the same LabView project as before, were everything was still working properly, and I can't find out what could be different. To answer the question from the error message, I am not using an external clock, only the internal one. I turned the device off, re-connected it, I was searching for some settings that I could change, but didn't find any and I created a new clock, all without success.
I would be very great full for any hints and pointers.
Cheers,
Gian-Marco
(838 Views)
Can you try shipping examples and see if they work?
ALE Consultants
(808 Views)
I followed the example described here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHblCAG&l=en-CH
and I am getting the same error messages.
(802 Views)
During the 'long break' did anything change on the computer?  I assume something has changed there in terms of its configuration, software that is installed, etc.
Since most/any example code is reporting the same errors it should be something more basic so to speak.
ALE Consultants
(799 Views)
The last time I used it was last July where everything worked was last July. And as far as I remember there have been no substantial changes, apart from some Windows updates.
(792 Views)
