CompactRIO Connection Issues
My NI Max software recognizes my Ethernet attached cRIO (NI cRIO-9024) but labview 2020 won’t... when using NI MAX to update software on the RIO, I get an error stating “the feature’s real time support for this target type may not be installed”
how should I work this problem out?
(413 Views)
Do you have LabVIEW Real-Time installed?  [NIPM is throwing a fit right now, and won't let me see my Installed Software so that I can look up the name of the module ...].  As you probably know, a cRIO has its own (NI-Linux RT) Operating System, and runs it own "Target" LabVIEW software, communicating (if appropriate) with Host software running on a Windows PC, with communication between Host and Target over TCP/IP.  Your error suggests that when you installed LabVIEW, you didn't install LabVIEW Real-Time Module ...
(404 Views)
