02-22-2016 09:38 AM
I am trying to convert a LabView 2012 project to LabView 2014, but have run into problems, namely I get the following error when I open the Main VI:
Compiler Error. Report this problem to National Instruments Tech Support. out of regs - no spill candidate found, reg 20576.
This VI is very large, so trying to find the source of the error doesn't seem to be trivial.
I have opened up the Heap Peek to delve into the VI and found the following:
For the FPHP the following entries are red:
693(1C) SelList
50343(40) BkUpListList
For the BDHP the following entries are red:
694(20) SelList
50348(40)BkUpListList
What does this information tell me? And how can I use it to fix my problem to make this VI compile?
02-22-2016 11:55 AM - edited 02-22-2016 11:56 AM
Having a VI that is very large is generally a bad sign - if it's too large, it might be that it is having trouble trying to convert it. Can you break the VI down into SubVIs before you convert the project?
How big is the VI / block diagram? You should try to keep your VIs to one 'screen' in height/width (to promote good use of SubVIs), but it's OK to have it scroll in one direction.
02-23-2016 06:45 AM
When I say large I don't mean in terms of window space, it all fits in one window.
What I mean is I have a state machine with 103 states, with one of those states containing an event loop with 75 cases.
Breaking this down into smaller sections is not a small ta
02-25-2016 10:54 AM
02-29-2016 08:19 AM
The VI has 103 + 75 cases, so 178 in total.
Found the source of my problem, one property node that seems to be causing the problem. Put a diagram disable structure around it though and the VI compiles and runs again. Now to figure out a work around to get the functionality of this property node working.
The property node sets the input impedance on an NI DMM, and is used with IVI drivers, only executing if it sees a PXI-4071(our only NI DMM, all others are regular bench top). It works fine in a standalone VI, but not within my main application.
02-29-2016 08:58 AM
