Conflict of 2 control events
Hi Pavel,
NEVER use "default if unwired" tunnels when you want to store values in shift registers!
Message 11 of 18
(1,332 Views)
Thanks for suggestions
I've wired phi and theta through all avent case.
These values are changed when "Regenerate B0" clicked, but events doesn't result B0x, B0y, B0z changes.
The new values phi and theta are taken into account once I modify B0max.
Best Regards
Message 12 of 18
(1,321 Views)
You need to force a Value Change event on the BOmax.
GCentral
Message 13 of 18
(1,310 Views)
Thanks, it works.
Unfortunately events created by B0max and Regenerate B0 aren't taken into account by XY Graph.
LabView doesn't allow to duplicate event - so I can't add B0max and Regenerate B0 into event case [1], where XY Graph is processed.
Any ideas ?
Best Regards
Message 14 of 18
(1,285 Views)
Hi Pavel,
you don't need to "duplicate" an event, you only need to enforce the next element by using the "Value signalling" property or by employing user events…
Message 15 of 18
(1,275 Views)
Hi GerdW,
Here I didn't properly understand what you mean.
Graph XY is processed in case [1].
I've employed "Value signalling" property for B0x, B0y, B0z in the case [3] where B0max event is processed.
I've searched for something similar for Graph XY to put it there ... but found nothing.
Cpild you please, develop a little bit your idea.
Pavel.
Message 16 of 18
(1,268 Views)
Accepted by Pavel_47
Those controls/indicators are do not have any registrations for a value change.  They are read in the [3] even case, but that case is not triggered by their value change.  Even then, you only need to have 1 of them trigger the event, not all of them which would just cause that event case to be called three times.
GCentral
Message 17 of 18
(1,261 Views)
Of course ...
Thanks !
Message 18 of 18
(1,254 Views)
