Connect Labview to PostgreSQL
Hello
I have a demand to integrate my system in LabVIEW with a PostgreSQL database.
The database was created by the company's IT team, and they gave me some information from the bank, such as:
Host
Port
User/Owner
Passowrd
Database
I'm trying to establish communication with the database with this information but I'm not succeeding, can you help me?
Message 1 of 8
(668 Views)
Can you share what have you done so far ?
Message 2 of 8
(666 Views)
Here is the VI, with the real data masked
Message 3 of 8
(663 Views)
connection strings can be found here
Message 4 of 8
(630 Views)
What I do is create a udl file with all the connection info. Do this by going to Tools-->Create Data Link.
Then I wire a path of that file to the input on the Open Connection.vi. This way I can test the connection in the udl interface and make sure I get the "Test connection succeeded" before I go to LabVIEW. Sort of like how you test the VISA connection in MAX before opening it in LabVIEW.
Message 5 of 8
(623 Views)
As an addendum, the .udl is a simple text file, so you can copy the content and use as Connection string if you don't want to use the file.
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 8
(594 Views)
Well I'll be. It is just a text file. At least the udl tool helps to get the connection string formatted correctly.
Message 7 of 8
(587 Views)
Oh yes, that's how i use it. 🙂
Qestit Systems
Message 8 of 8
(568 Views)
