03-23-2023 08:41 AM
Hi, I am still very new to LabView and DAQs, and have been trying to connect magview MVM-002-Q to a USB6009 DAQ card, but unfortunately with no success. The connections I made are similar to the one shown in the data sheet, using PFI and the +5V pins with the GND as well. But I am not sure how can I read the frequency. I tried using MATLAB but with no success. I even tried with DAQmax test option when it first opens, but it keeps showing 0 count. Should I build a labview program for it? If yes, how can I start? I would appreciate any kind of help.
Best,
Hamza
03-23-2023 11:54 AM
How did you do the wiring? Can you share your wiring diagram?
How you tried to capture the pulse output from the sensor using a scope?
03-23-2023 12:00 PM
I can see a pulse using a oscilloscope. However I believe I need to build a labview program to be able to read it. Do you have any suggestions on how to start? or if there are some examples?
03-23-2023 01:37 PM
You should start with Using Test Panels in Measurement & Automation Explorer for Devices Supported by NI-DAQmx
Once the acquisition is working with the test panel, you can go ahead with programming. The LabVIEW examples are available at Help >> Find Examples... >> Hardware Input and Output >> DAQmx
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
04-15-2023 08:24 AM
I found out a solution. The reason why I was not detecting any output on Labview. The output voltage was higher than the maximum detectable voltage by my daq card, thus i needed to add an extra resistor in parallel.
