12-04-2007 12:31 PM
12-05-2007 11:00 AM
12-05-2007 04:32 PM
09-07-2010 08:47 AM
hi,
i have the same problem, using agilent DSO3202A scope with usb,
and already download the match driver at NI site (also download NI-VISA),
but the driver don't work..
can anyone tell me what should be the visa resource name?? the error is :-1073807346
could it be something else??
thanks!!
09-07-2010 09:48 AM
Click on the little arrow on the right side of the VISA Resource Name control. You should see a list of available resources. If your instrument is not listed, then there is probably a problem with the installation of the Agilent USB driver. The instrument must be listed in MAX before you can use it. Whether or not the instrument driver is installed or not is irrelevant.
08-14-2013 06:42 PM
Hi there,
I think the issue is that the DSO3062A will not be recognized by LabView as a GPIB instrument through the USB connection. If you check out the 3000 series manual (http://cp.literature.agilent.com/litweb/pdf/D3000-97016.pdf) you'll notice on page 8 it says you can't use the USB for programming, it can only be used with their scope software. You need the N2861 module installed on the back to connect via GPIB, and then a GPIB interface to your computer. I hope that helps.
-jmart
