06-28-2023 01:43 PM
I currently got a Fusion 4000x Syringe pump and I have been trying to connect it to LabVIEW using the drivers provided by the company. All the examples from the company gives me an error. does anyone have a modified example that I can use with my pump? Also, every time I try to scan devices it doesn't show any devices connected. I'm kind of new using LabVIEW. my pump is connected to my pc through a usb-b to usb cable. I have attached the manual of the pump.
Fusion4000-X-Manual.pdf (chemyx.com)
06-28-2023 02:58 PM
I installed the drivers and didn't received any errors.
Make sure you have installed the VIPM (VI Package Manager) VIPM - Download
You need to install the drivers from this page
LabVIEW™ Driver for Chemyx Smart Syringe Pumps
06-28-2023 03:26 PM
Just did. Now I get a notification saying that the syringe pump can’t be detected.
06-28-2023 03:36 PM
Did you select the correct port before running the program?
-AK2DM
06-29-2023 09:11 AM
Yes, I selected the right port. When i hit run should I click on something on the syringe pump? to make the pump run by the computer? also, there's no more errors in drivers' examples. only thing is that nothing happens when I hit run on LabVIEW.
06-29-2023 09:19 AM
Also, this is what it shows every time i try the examples.
06-29-2023 09:40 AM
Check the device manager : it will show what ports are detected in your computer.
06-29-2023 09:49 AM
com12 Is the syringe pump
06-29-2023 09:54 AM
Did you check the system settings of the pump ? (page 27). Are you using DB 9 or USB on the syringe ?
06-29-2023 09:54 AM
ive been trying with this code. but it shows me this error too.
