Control of a digital stepper motor
Hello!
Basically, I am building a PID controller whose output must be pulses that move a stepper motor linearly. Does anybody here could share some codes or iformation about how to do it?
(967 Views)
Hi institutotect,
Basically you need a code to read your process value (pv) for PID input, a PID function to calculate an output value and a code to drive another DAQ device to output your pulses. What have you tried so far and where are you stuck?
When you use a PID, which generates a changing output value, then your stepper motor will not move "linearly"…
(945 Views)
I already have the angle input from a rotary incremental encoder.
This PID will control an inverted pendulum that can move only in x axis
My ideia is to built a general PID controller and adjust the gains as I analyse the experiment. Do you think it make sense?
My doubt now is how to link the ouput from de PID with the stepper motor.
Thanks!
(925 Views)
Hi insitutotect,
What does your motor driver expect?
How is the motor connected to your computer?
You didn't tell any details so far…
(922 Views)
