10-04-2022 01:28 PM
Hello!
Basically, I am building a PID controller whose output must be pulses that move a stepper motor linearly. Does anybody here could share some codes or iformation about how to do it?
10-04-2022 02:26 PM
Hi institutotect,
Basically you need a code to read your process value (pv) for PID input, a PID function to calculate an output value and a code to drive another DAQ device to output your pulses. What have you tried so far and where are you stuck?
When you use a PID, which generates a changing output value, then your stepper motor will not move "linearly"…
10-04-2022 02:55 PM
I already have the angle input from a rotary incremental encoder.
This PID will control an inverted pendulum that can move only in x axis
My ideia is to built a general PID controller and adjust the gains as I analyse the experiment. Do you think it make sense?
My doubt now is how to link the ouput from de PID with the stepper motor.
Thanks!
10-04-2022 03:01 PM
Hi insitutotect,
What does your motor driver expect?
How is the motor connected to your computer?
You didn't tell any details so far…
