Conversion of LabVIEW 5.1 code to 8.5
I got some source code made in LabVIEW version 5.1, but I have installed LabVIEW 8.5 on my system. When I try to open the source code, so there appears an error message, that says: version 5.1 is too old to open in 8.5. Please, is there a possibility to open the source code in LV 8.5 (conversion or something like that)? Thank you!
Message 1 of 102
(7,599 Views)
You will probably have to go through one or two labview versions. Try speaking direct to your NI representative.
Ray Farmer
Ray Farmer
Message 2 of 102
(7,584 Views)
Hello.
Could you attach the source code?
We could have a look how to convert it.
Regards.
Romain D.
National Instruments France
Message 3 of 102
(7,583 Views)
Here is the source code needed to be converted. May be it will need open some more VIs, but I don't know which ones, because I can not open it... ;) http://www.oprox.cz/pokusy/bmcusb-ad_analog.vi
Message 4 of 102
(7,571 Views)
Hi LVO
here is it for LV7.1. Now you should be able to open it.
Mike
Message 5 of 102
(7,566 Views)
Dear Mike! File you have attached have been opened fine, but there are 4 more VIs to convert (needed by converted file). Would you be so kind to make them? Thank you very much! http://www.oprox.cz/pokusy/bmc.zip
Message 6 of 102
(7,554 Views)
Hi LVO
see attachment.
Mike
Message Edited by MikeS81 on 02-04-2008 03:38 AM
Message 7 of 102
(7,543 Views)
Dear Mike! Thank you very much, but be so kind and try to convert to me two more VIs (they were as subVIs in bmcOpen.vi). Thanks a lot! http://www.oprox.cz/pokusy/bmc2.zip
Message 8 of 102
(7,536 Views)
Hi LVO
now they are all together. I check it on my pc and the only think that i have a broken arrow is because i don´t have the dll.
Mike
Message 9 of 102
(7,529 Views)
Everything works fine now. Thank you very much!
Message 10 of 102
(7,522 Views)
