Convert 32 bits string in a hex number LV 7
Hi!!
I have a 32-bit string that I need to convert a hexadecimal number, which program can I do?
Someone can help me?
(3,119 Views)
Accepted by joaolima4
Each character in a string is a BYTE.  So are you saying each of those I8s are 0 or 1?  If that is the case, then why not just use booleans (TRUE or FALSE)?  An array of booleans would make this really simple since you could just use the Boolean Array To Number primitive to do the conversion for you.
GCentral
(3,116 Views)
Do you mean to say you have a string (Ascii, text data) of the form "01001011010001010010111001010011"?  [If I counted correctly, there are exactly 32 0's or 1's in that string].  Have you looked at the String functions?  Have you looked at "Scan from String"?
(3,092 Views)
I just noticed that you specified LV 7, which I assume is LabVIEW 7.  I don't have LabVIEW 7 on this PC, so I'm not sure if the Scan from String function goes back that far (I'm pretty sure that it has been around for at least 6-7 years, though).  But there should be some appropriate String function, I would think ...  If not, get "modern" LabVIEW and you will have a much more powerful Software Platform than LabVIEW 7.
(3,090 Views)
So I had a VM with Windows XP and LabVIEW 7.0 -- Scan from String is there, you should be "good to go".
BS
(3,085 Views)
