Convert Array of dec values in string
i search the siplest way to convert array with dec values (ascii coded) in a string.
For example Array with 50 46 49 to string 2.1
Sepp
(1,946 Views)
Sepp
Talking about ASCII or hex conversions is always confusing.  As a result, I'm not quite sure what you are trying to do.  Don't those ASCII values already correspond to the string you want to convert to?
Bill
CLD
(Mid-Level minion.)
(1,945 Views)
Hi Bill,
content of array is for example 50 46 49 and i will convert in string "2.1"
Input array with dec values, output correspond ascii characters in a string.
Regards Sepp
(1,934 Views)
(1,928 Views)
Accepted by sepp70
@sepp70 wrote:
Hi Bill,
Regards Sepp
I get it now; I should've gotten it the first time, sorry.  Just use the "Byte Array to String" function found in the Numeric --> Conversion palette.
Bill
CLD
(Mid-Level minion.)
(1,927 Views)
wiebe@CARYA wrote:
I think he meant he has an array of u8.  Talking about these kinds of conversions are always tricky to me.
Bill
CLD
(Mid-Level minion.)
(1,924 Views)
Agreed.
If the input is an array of numerics, there's no point (or difference) in mentioning that it's decimal encoded.
If the input is an array of decimal encoded strings, it's quite different.
It would be better to have a VI with input\output specified.
(1,919 Views)
