Convert hex string to number
As the attached vi, I am tring to convert string(hex) into number(U8), but seems not work.
Any suggestion, thanks.
Message 1 of 14
(18,826 Views)
Alex,
isn't this what you're looking for?
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 14
(18,823 Views)
Accepted by alex.
Now you have 2 solutions :
Kind regards,
- Bjorn -
Message 3 of 14
(18,819 Views)
What does your "hex string" look like? Is it human readable or it the raw bytes?
Raw bytes, then do as ABCPrograms
If you have a two byte string that represent a human readable hex number 0-255 (00 to FF) like "1A"?
Then
Omar
Message 4 of 14
(18,802 Views)
The question is not clear, because "hex" is very ambiguous. Please put a typical string inside the string control and make it the default, resave, and attach once more. Then tell us what result you expect.
How many bytes are in the string?
  • If it is one byte of a binary string, typecast it to U8. (It would be silly to go to a byte array)
  • If it is two bytes of a hexadecimal formatted string (exclusively containing characters 0..F), scan it using %02x format.
  • If it is more than two bytes, you need to provide us with more information.
Message 5 of 14
(18,796 Views)
Hi All
I am trying to converter 4 bit hex string to number. I know the right results. But I do not know how converte. Please see the attached vi
Please help me.
Message 6 of 14
(17,774 Views)
duplicate post, continue here
Hong: What's the point of creating 3 identical posts in 3 different threads?
Message 7 of 14
(17,768 Views)
Hi Alex,
But how to convert the unsigned byte array into a decimal number? I think that was the question.
Cheers
Message 8 of 14
(11,479 Views)
Hi dadest,
Simple answer: Just display that U8 array in an array indicator. Set the display mode to decimal.
More complex details:
How do you want to display your U8 array?
Do you need any special conversion?
Can you provide an example with some input data and expected result?
Message 9 of 14
(11,467 Views)
Hi GerdW,
Thanks for the reply. Yes, I can just display as decimal but the thing is that I want to be able to use that data for calculations.
For example, the maximum output of my circuit is 1.3V that corresponds to 0514 (HEX) which I am reading using Bluetooth LE.
So if I read 025C (HEX), that corresponds to 604dec and that turns out to be 0.604mVolts. I want to be able to continuously read this voltage and display it as a waveform.
Cheers.
Message 10 of 14
(11,433 Views)
