Convert project item type string to type GUID
Hi all,
Is there a generic way of getting the type GUID associated to a project item type string ?
Also, I don't necessarily have an instance of the project item in my project, so I cannot use directly the ProjectItem property "Type GUID".
Example:
"Elemental IO"          gives  "{A117026A-AD51-4C63-8341-085C842E9D22}"
"Library"                    gives  "{ABC740D6-F254-4BBC-5675-8858F35B820E}"
"FPGA Base Clock"  gives  "{EF04866F-AE99-4C3F-B28B-879B709E5BBE}"
Second question to go further:
Are the type GUIDs always the same for a given type string ? Or is it dependent from projects or LV versions ?
For example, will items of type string "Elemental IO" ALWAYS have a type GUID of "{A117026A-AD51-4C63-8341-085C842E9D22}" ?
If the answer is yes, I could definitely have an hardcoded conversion table and the problem would be solved 😅.
Thanks.
(658 Views)
@raphschru wrote:
Hi all,
Example:
Not that I know of.
You can use ProjectItem - LabVIEW Wiki, and indeed make a lookup VI...
The GUIDs seem to be stable across version. These GUID serve a purpose, and it would be inconvenient for everybody including NI to change them. There's no guarantee though. If this is a good reason for NI to change them, they will change.
Even if those GUIDs change in a future version, you can make a hardcoded conversion table. That would solve the problem. If they change, you can use a conditional disabled structure to make the table version sensitive.
(640 Views)
