01-03-2011 08:53 AM
I need to convert an image from Grayscale I16 to RGB U64, but it doesn't work (I have joined a zip file).
I think there is a bug in the NI Vision, or it's not implemented because I have no problem to do it from Grayscale U8 to RBG32.
Can you help me to find a solution to do that?
I need to use ReplaceColorPlane function or equivalent because I have to perform various treatments on each layer (RGB).
01-04-2011 03:36 AM
Nobody has an idea?
Please help me :mansad:
01-04-2011 08:11 AM
Hi
If you put a probe to the outgoing image you can verify the pixels are there. Also if you probe the frontpanel image you can see that the RGB values are correct.
But like already with I16 images you have find a compromise because standard graphic adapters can only display 24 Bit colors.
Where would you display a grey (because all planes are like) U64 image?
But that is still better than the (I feel) ridiculus SIGNED format for I16. I used to work with only the upper 15 bits. But still you have to find some compression to come back to 8 for display.
Gabi
01-13-2011 02:15 AM
Hi Badgones73,
The U64 image is composed of four U16 values (R, G, B and alpha). LabVIEW represents 16-bit images as an I16. When the IMAQ Extract Color Planes is called, the U16 value must be converted into I16 values. This is done by converting all values with a MSB of 1 to a value of 0. This means all the values from 32,768 to 65,535 are now 0. To avoid using losing these values, you must read the image into LabVIEW without using the vision functions.
Once you have extracted the U16 values, they can be converted from U16 images to I16 images. Once this is done, you will be able to use all of the Vision functions.
Also, i invite you to read the information on our website:
http://digital.ni.com/public.nsf/allkb/ED42C55C29B9B34C862570A60079952E?OpenDocument
Rémi D.
National Instruments France
