06-17-2010 10:46 AM
06-17-2010 11:12 AM
06-18-2010 03:23 AM
06-22-2010 12:30 PM
Hello TC_Magic,
As you pointed out yourself, this is a problem very specific with that particular PC. Nothing similar has been reported before, and since your appication deploys fine on other PCs, then we can only look more closely at settings on the computer where the issue appears.
Are there other languages installed on Windows? If you go to your Control Panel and navigate to your "Regional and Language Options", then you can select the "Languages" tab and click on the "Details" button. Can you see other languages installed there? This might be the root of this problem.
This, in combination with the language support you select in your Application properties in the Build Specifications of your LabVIEW project, will cause the menu of your executable to adopt to different languages. Go into your project, open your Build Specifications for your executable, then select the "Run-Time Languages" from the Category section, and then uncheck the "Support all languages" option. Then, uncheck all languages apart from English, and click on "Build". Redeploy your application and check if this fixed the problem.
Let us know how you get on.
Kind Regards,
Michael S.
Applications Engineer
NI UK & Ireland
06-24-2010 03:10 AM
Thanks for all your help.
I took all the Labview files off the computer (I think I didn't take SP1 off last time) and re-installed the software and the corrupt font had gone.
06-24-2010 03:37 AM
Hello TC_Magic,
Thanks for getting back to us!
All the best with the rest of your application!
Kind Regards,
Michael S.
NI UK & Ireland
