Could not delete 'temp' folder when building installer.
Hello All,
When building the installer, I have no idea why this error come out recently. it is ok before. while building the single 'exe' is OK.  is there something wrong with the windows update?it seems the installer is working, but can I resolve this issue?
here is the error information.
Click the link below to visit the Application Builder support page. Use the following information as a reference:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> IB_MSI.lvclass:Build.vi >> IB_MSI.lvclass:Engine_Build.vi >> NI_MDF.lvlib:MDFBuildDist_Close.vi
The following errors and warnings were recorded during the build:
Error:
Error deleting directory.
Details:
Error deleting directory "D:\***(installerpath)\temp\".
Additional details:
Error deleting directory "D:\***(installerpath)\temp\dp\".
Internal system error.
An internal system operation returned the error "Access is denied.".
Code:
-12
(255 Views)
It seems the deletion of this folder requires elevated privileges...
Have you tried running LabVIEW as an administrator to build your installer?
Raphaël.
(225 Views)
Hi raphschru,
Thanks for the reply.
I did try to run with an administrator account. but it seems the same.
(166 Views)
It is strange that I got an email telling me there is a new reply from "mahakpr2". but I can't  see the reply here.
I didn't create and delete the folder manually. It is handling by the "LabVIEW installer builder". and I don't know why it happen recently.
(114 Views)
"mahakpr2" is likely a bot/spam account, which is why the advice was a bit off.
The message was deleted by a forum administrator.
(105 Views)
