Count up and down with constant
I need to create a program that let you select the start and stop number and start count up and after it wounld start counting down from where it stop. The number would incresing from the constant that also the user is going to select.
Message 1 of 18
(8,302 Views)
Show us the vi that isn't working for you.
Bill
CLD
(Mid-Level minion.)
Message 2 of 18
(8,299 Views)
What have you tried so far?
I'm guessing you will need to use some or all of these:
Cheers
Message 3 of 18
(8,292 Views)
  • If it is a constant, the user cannot change the value. So what do you mean by "select"?
  • Why do you call it "stop" if it starts counting down at that value? call it "top" instead, for example. 😄
  • Is "Stop" guaranteed to be larger thant "Start"?
  • How fast should it be counting?
  • Should the output be an array of all generated numbers or a scalar that changes over time?
It would help if you could give an example of the desired output, e.g.
start=5
stop=8
output = 5-6-7-8-7-6-5
Is this about right or do you want something different?
Message 4 of 18
(8,278 Views)
Hope your requirements looks simple but you might have narrated your concept bit informative.
As mentioned by altenbach you can't change the value of constant... that's the reason it is named as constant.
Can have a control outside loop,where user can select value.in the loop you can decide until which value you need to increment and then you can decrement the same number of times.
Use shift register to maintain value.which holds incremented and decremented value.
Message 5 of 18
(8,250 Views)
You don't need any shift registers! Here's a bunch of primitives sufficient to generate the required up-down ramp. All that's missing are the wires. 😄
Some assembly required 😄 😮
(there are many ways to do this of course.)
Message 6 of 18
(8,245 Views)
The user would only enter the number only once and run the program. Have a a number that would stop from counting up and start counting down. I would to graph the number over time.
Message 7 of 18
(8,242 Views)
Don't let the user change diagram constants. Use controls like everybody else.
(diagram constant are for the programmer, not for the operator!)
(My code above (once assembled!) creates an array of number that you can wire directly to a graph;))
Message 8 of 18
(8,239 Views)
There is also the Ramp VI in the Signal Processing->Signal Generation palette that could do the job for you.
GCentral
Message 9 of 18
(8,222 Views)
Altenbach- the "Ikea" of LabVIEW 🙂
Message 10 of 18
(8,212 Views)
