04-03-2023 01:25 PM
Hi collin,
@collin_g_10 wrote:
But what it the best way to count the ammount of times that the blade will pass through.
You "just" count how often the voltage rises above a certain limit…
04-03-2023 05:32 PM
Would you please post your code so you can get help?
04-04-2023 03:58 PM
Yeah I am not sure how to create a code count everytime that is hits the voltage of 10.5557 but here is the code I have so far.
04-04-2023 04:59 PM - edited 04-04-2023 05:00 PM
Hey my friend,
I got you.
See the attached code. For more questions or help request, feel free to ask. People would be glad to help you.
GRCK5000
04-04-2023 07:31 PM
@collin_g_10 Test the code above ☝️ and let me know if it works for you. If not, we will look further what's going on.
04-27-2023 10:31 AM
So I had used your code that you had given to me, The program is not reading the propeller fast enough. Is that something that is happening because of the program, or do you not think that the sensors can read the propeller fast enough
04-27-2023 10:49 AM - edited 04-27-2023 10:50 AM
Integrate your working module in the attached VI and Map the output of the data acquisition to the comparator.
Whenever it meets the Values it gets incremented else it maintains the same count
04-27-2023 10:55 AM
Stay away from expressed VI. It has built-in configuration that can affect your program performance. Use Daqmx VIs.
04-27-2023 11:45 AM
@PalanivelThiruvenkadam The problem with your code is that it will keep counting if the led stays ON. I have attached the code to see the difference. I would say let the LED ON for 5 seconds and you will see your counter will keep counting. The OP wants to count how many times it goes above 10.5.
The only inconvenience with mine is slow at counting you start increasing loop timing and it looks convoluted. For example: 1000 ms. I have attached a code that combines yours and mine to see what I am talking about.
04-27-2023 11:54 AM
Since its not a Boolean button which will always be true, Whenever the acquired data is greater than 10.5 it will increment else maintains the same number.
If the requirement is only to count whenever there is transition (Low -high), then I my logic needs to be changed - Simple implies function do the job (Still I won't recommended feedback node).
