07-02-2009 07:24 AM
Can i use a "Create PXI Format Hard Drive Disk" created from LV 8.5.1 ver for formating the PXI RT controller which is having LV RT 7.1.
07-02-2009 07:40 AM
I think you can, but you'll need LV (RT) 7.1 on the host PC to install LV RT 7.1 on the PXI controller using MAX after formatting it.
(Unless you have an image created by the RT replication toolkit, but then other problems might arise...)
Daniel
