04-10-2018 10:45 AM
Hello the forum,
i'm trying to code a VI that will be built as an EXE and called by another VI using the System Exec function.
The EXE should be able to:
1. read an input string from the console that will be treated as soon as the called EXE starts running
2. write an output string to the console that will be treated as soon as the called EXE ends running
Here's the result of my search (in terms of links):
https://forums.ni.com/t5/LabVIEW/how-to-make-a-VI-write-to-standard-output/td-p/347392
https://forums.ni.com/t5/LabVIEW/console-app-from-labview-VI/m-p/77569
https://forums.ni.com/t5/LabVIEW/Standard-output-on-system-exec-VI/td-p/3358128
http://dslweb.nwnexus.com/~ast/dload/guicon.htm
https://docs.microsoft.com/en-us/windows/console/getstdhandle
https://docs.microsoft.com/en-us/windows/console/writeconsole
https://forums.ni.com/t5/LabVIEW/Calling-subroutines-from-dll/td-p/151367
And attached there's a screenshot of what i coded on the diagram of the called EXE. A file is generated with the errors details and the values coming from the Kernel32 funcitons. An error code 1097 appears as the first function is called.
Any clues on how to achieve the goal?
Thanks!
04-10-2018 02:49 PM
@aRCoi'm trying to code a VI that will be built as an EXE and called by another VI using the System Exec function.
I think more information is needed here. A simple explanation of what you are trying to do besides:
What does "treated as soon as the EXE starts" and "treated as soon as the EXE ends running" mean?
04-11-2018 03:02 AM
I overloaded the previous message with unuseful info. The two points can be modified as follows:
The EXE called by the System Exec function should be able to:
1. read an input string (containing parameters) from the console
2. write an output string (containing results) to the console
04-11-2018 03:07 AM - edited 04-11-2018 03:08 AM
Hi arco,
1. Enable command line parameters when building the EXE. Read the command line parameters using an App property node…
2. You already linked to threads discussing this issue. (LabVIEW is a GUI tool, which don't support console output…)
04-11-2018 07:17 AM - edited 04-11-2018 07:18 AM
@GerdW
Really? I thought LabVIEW could do everything... 😉 ...and it seemed to me that someone implemented something similar.
Am i really forced to use (for example) a temprary file to exchange data to and from the called EXE?
04-11-2018 07:32 AM
@aRCo wrote:
@GerdW
LabVIEW is a GUI tool, which don't support console output…Really? I thought LabVIEW could do everything... 😉 ...and it seemed to me that someone implemented something similar.
There is a big difference between what LabVIEW can do, and what LabVIEW can do practically.
There is also a difference between what can be done in LabVIEW, and what anyone can do in LabVIEW.
Even if it has been done, I doubt it turned out to be an elegant solution.
Big question is why would want to do this? An exe seems like the least convenient solution. Make a .dll, it's designed to be used like this. A .dll is an exe in almost every aspect. It just adds loading\unloading functions (that are irrelevant in this context), and extra entry points (although an exe can have those as well).
04-11-2018 09:10 AM - edited 04-11-2018 09:11 AM
wiebe@CARYA wrote:
@aRCoBig question is why would want to do this?
My question exactly...
Tell us what exactly you are trying to accomplish here and maybe we can come up with a better way.
BTW: LabVIEW can NOT do "everything". LabVIEW is a tool and while it is often the right tool for the job, sometimes it is not.
04-18-2018 01:52 AM - edited 04-18-2018 01:53 AM
Hi all,
finally I implemented two ways:
1. The EXE way, that, instead of read/write the console, it uses files to accomplish the same goal
2. The VI way, setting/getting directly the values of the input/output terminals of the connector pane of the called VI (builded inside a LVLIBP)
Which other solutions could I have implemented?
04-18-2018 03:29 AM - edited 04-18-2018 03:30 AM
04-18-2018 03:41 AM
wiebe@CARYA a écrit :
A dll.
Yes, thanks! I'll try to find the time to implement this other solution 😉 Have a nice day
