D2.2 help
okay so i almost have it put together. i am super new to the class (only 2 weeks in) but i am trying to figure out how i can make a numeric indicator only show numbers greater than 0. since i can only use  mathmatic functions as inputys to numeric indicators this is really stumping me.
thanks
(2,874 Views)
Could you please provide more info as what you mean by greater than "0"?
-If you want to display only positive integers you need to select indicator data type to "unsigned".
uday
(2,869 Views)
Hi James,
Use a MinMax function before your indicator. Wire a "epsilon" constant to the 2nd input of MinMax and use the Max output to get a number "greater than zero" to show on your indicator:
indicator := MinMax(input; epsilon)
General recommendation:
- You thread title is silly: everybody is looking for "help" in a forum and "D2.2" is no LabVIEW specific term either. Use a better title the next time!
- Usually you should also show your VI and tell us where you are stuck. Nobody will do your homework for you from scratch!
(2,866 Views)
