DAQ Assistant not launching (LV 2013)
Hi all,
I have LabVIEW 2013 installed, and in all the tutorials it says that the DAQ assistant should launch once it is dropped onto the Block Diagram. I have been doing so (Express > Input > DAQ Assistant on the Functions palette) but nothing launches when I put it on the diagram.
Why is this happening? Are there any solutions?
(3,812 Views)
The default setting in LabVIEW is to configure when dropped, but this box can be unchecked. Double-click to configure if it doesn't automatically show the popup.
To change the setting go to Tools > Options > Block Diagram tab > "Configure Express VIs Immediately"
Cheers
(3,807 Views)
 Hi James,
I have tried double clicking it, and nothing is happening. Do you know why this is?
(3,798 Views)
Please provide the version of DAQmx that you installed.
(3,785 Views)
I installed DAQmx version 14.0
(3,779 Views)
You could try a repair or install the latest - http://www.ni.com/download/ni-daqmx-14.5.1/5271/en/
(3,774 Views)
Yup, sounds like a bad install 😕
Cheers
(3,768 Views)
