DAQ Hardware for ICP Accelerometer
Which one of these modules would you recommend and why for ICP accelerometer (datasheet attached)?
NI 9234
NI 9232
Thank you for any suggestions.
Pawel
(2,743 Views)
Dear Pawel,
based on the specifications you have provided, both cards can be used with the sensor. I'd suggest the 9234, as it has more channels and uses the ADC range better (since your signal is around ±5V at maximum acceleration).
Kind regards:
Andrew Valko
National Instruments Hungary
(2,670 Views)
