07-21-2010 08:43 PM
I am trying to read an analog voltage signal and display it on the front panel. I have a PCI card installed that is recognized by MAX. I can see the signal when I use "test signal". The DAQ assistant express VI does not give me the option to create an indicator, however. "Create" does not even appear on the shortcut menu when I right click the DAQ assistant on the block diagram. How do I display the signal on the front panel?
I am using labview 7.1 with NI-DAQmx 7.2
07-21-2010 08:50 PM
It's not missing anything. The output signal is what you wire to the "data" input. The test signal is just that - a quick test when you are configuring. It is not output when you run the VI.
07-21-2010 08:56 PM
Thanks for responding. How do I create an indicator so I can see the signal on the front panel and maybe flash an LED or something?
07-21-2010 08:59 PM
Depends on how you are generating the data and what the data is. If you are generating a sine wave, use a graph.
07-21-2010 09:02 PM
I am using a pulse genertaor to generate voltage spikes. I am sending them to a PCI card. I would like to flash an LED everytime the voltage spikes. How do I use this signal as an input on my block diagram?
07-21-2010 09:03 PM
This is just a test experiment that I am running to get used to using Labview with real intrumentation.
07-21-2010 09:17 PM
What 'pulse generator'? Do you mean Pulse Pattern? If so, you would wire the array output to a for loop wih a comparison function and a delay to simulate the timing. That might not be a reasonable simulation, though. Depends on how you will eventually be acquiring the real pulses.
07-21-2010 09:20 PM
I am aquiring real pulses. I have a real analog signal routed to my PC.
07-23-2010
06:29 AM
- last edited on
11-12-2024
09:06 AM
by
Content Cleaner
Hi dermen,
You will need to select the output of the signals terminal if you would like to create an indicator rather than the entire DAQ Assistant itself. Here is a brief video that walks through setting up a measurement, using the DAQ Assistant for acquisition, and displaying the data on a waveform chart. This is a part of Getting Started with NI Products, where you can begin with the environment basics and also watch a demonstration of saving the data to a file. This is a useful reference as you begin to build your application. Hopefully this helps!
07-23-2010 01:53 PM
Thanks!
