DAQmx Logging on cRIO 9042: Error -201310
Hi everyone,
I would like to use DAQmx logging on a cRIO 9042. Reading waveforms and logging those to TDMS "by hand" works fine. According to this page DAQmx logging should also be possible: Log TDMS Measurements in a Real-Time Application. Unfortunately, I get this error:
Error -201310 occurred at DAQmx Start Task.vi:7220001
Possible reason(s):
TDMS support is not installed or is too old. Use an NI-DAQmx runtime that includes TDMS support, or install a supported version of TDMS from a stand-alone installer.
I'm pretty certain the driver is not too old. I'm using LabVIEW 2020 and the cRIO has these versions installed (excerpt):
CompactRIO Support 21.0.0.49153-0+f1
LabVIEW Real-Time 20.0.1.49159-0+f7
Linux RT System Image 21.0
NI-DAQmx 21.0.0.49316-0+f164
Any ideas?
(2,018 Views)
Hi cordm,
@cordm wrote:
Possible reason(s):
Any ideas?
Is there a separate "TDMS support" package to be installed?
(1,984 Views)
Did you find an answer to this? I encountered the same thing
(1,461 Views)
I did not find a cause for this. In the end, I installed a different system image version and that was the end of it. It might have been a mismatch between LabVIEW versions or something went wrong in the original installation. I used LabVIEW 2020 for development.
The system is gone now, but the last installed image was Linux RT System Image 20.7.0
(1,430 Views)
Accepted by cordm
Found, It is a bug #1839526 in DAQmx versions <21.8.
https://www.ni.com/en/support/documentation/bugs/22/ni-daqmx-21-8-bug-fixes.html
(1,343 Views)
