10-20-2015 12:34 PM
I opened my old vi (2012/2013) in Labview 2015, all the DAQmx Switch palettes have a big Red X on the VI's.
as shown here:
Is this something that has changed in Labview 2015?
Is there a way to migrate the old files to the latest version?
10-20-2015 12:48 PM
Is there a specific popup if you try to open the VIs?
A solution may be to replace them with the appropriate VIs from your palette.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
10-20-2015 12:55 PM
If I double click on any of those VI, the sub VI opens up and I do not see any errors within those subVI from what I can tell.
Here is a screen shot of the block diagram of "DAQmx Switch Set Topology and Reset.vi"
I don't have the physical hardware to check if the VI is still functional.
10-20-2015 01:00 PM
If the VI opens and doesn't have a broken arrow, I think it might run okay... It may just be a discontinued version and the X is just telling you to replace it if you can.
Cheers
