DAQmx Switch VI have red X
I opened my old vi (2012/2013) in Labview 2015, all the DAQmx Switch palettes have a big Red X on the VI's.
as shown here:
Is this something that has changed in Labview 2015?
Is there a way to migrate the old files to the latest version?
(3,900 Views)
Is there a specific popup if you try to open the VIs?
A solution may be to replace them with the appropriate VIs from your palette.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,886 Views)
If I double click on any of those VI, the sub VI opens up and I do not see any errors within those subVI from what I can tell.
Here is a screen shot of the block diagram of  "DAQmx Switch Set Topology and Reset.vi"
I don't have the physical hardware to check if the VI is still functional.
(3,877 Views)
Accepted by topic author vikasg
If the VI opens and doesn't have a broken arrow, I think it might run okay... It may just be a discontinued version and the X is just telling you to replace it if you can.
Cheers
(3,871 Views)
