DSC module: crash with OPC UA client il LV 2012
I'm working on OPC UA project in LV 2012. In the client side, under windows 7, I had a crash registering a byte array tag with the "Add Monitored Nodes VI". When the tag was updated, labiew crashed with teh following error:
I discovered the problem: in the server the tag was ByteString instead of Byte Array and I solved in my application. The question of solidity of the software for a common mistake is still present.
Thanks in advance.
Sandro
(3,062 Views)
Hi Tonch,
are you correctly managing the error wire?
Usually a correct error management will make the application more stable.
Hope it helps,
FBM
(3,046 Views)
For better understanding I attach the example (client windows, server RT). The problem occours when a generic byte array is written into a ByteString type at the server side. Then at the client side a crash happens when the event structure traps the data change.
It is not possible trap the erro before the crash. On my system it crashes any time the array is wrong.
Sandro
(3,036 Views)
Hi Sandro,
in my opinion the first thing to do is to investigate in the error log.
To open it, follow the steps explained at this link:
http://digital.ni.com/public.nsf/allkb/7E9EBE4CA3B6DCE786257633005E7121?OpenDocument
Hope this helps, let me know.
Bye
FBM
(2,984 Views)
I don't know why, but LV last time didn't propose me the error pop-up and the error log folder was empty. May be because I was targetted to the RT environment also?
Now, with the RT server deployed I was able to retrieve the errors.
The MS Win error report:
Problem signature:
  Problem Event Name: APPCRASH
Application Name: LabVIEW.exe
  Application Version: 12.0.0.4027
  Application Timestamp: 50574342
  Fault Module Name: LabVIEW.exe
Fault Module Version: 12.0.0.4027
  Fault Module Timestamp: 50574342
  Exception Code: c0000005
  Exception Offset: 005d1761
  OS Version: 6.1.7601.2.1.0.256.48
  Locale ID: 1033
  Additional Information 1: 4c07
  Additional Information 2: 4c07d344758da30e0b739df670ed1b50
  Additional Information 3: 7dc2
  Additional Information 4: 7dc271b289155588ff44180592900811
The LV error report is attached. I sent it with the automatic sender as report e2d8cb76-200e-467d-8b7b-c64ee1c18893
I discovered that the error occours sending empty regular byte array also.
sandro
(2,976 Views)
Hi Sandro,
looking in the client.vi of the LV example I saw that after the delete monitored nodes.vi, also delete subscriptions.vi and disconnect.vi must be used, linking also the error wire 'till the end and to a simple error handler or an error out indicator.
Maybe that's the reason why you had an unexpected crash.
Let me know if it works! 🙂
Bye
FBM
(2,960 Views)
