Darren's Occasional Nugget 09/26/2022
here is an attached xlsx that doesnt seem to work.  it is strange though because when i open it and re-save it, it works fine.
Message 51 of 53
(267 Views)
That .xlsx file contains tags that I haven't seen before... more specifically, they are formatted as <x:c> instead of <c>. The file must have been saved with an older version of the Open Document standard than any of the test files I used when I originally wrote the VI.
Anyway, here's an updated version, it appears to read your old file fine. Let me know if you have any other issues.
Message 52 of 53
(238 Views)
thank you very much for this.  i also saw you added the "workbook2.xml" fix which i was also running into occasionally.
Message 53 of 53
(188 Views)
