Darren's Occasional Nugget 11/14/2013
I just realized I haven't posted a nugget about my favorite LabVIEW 2013 feature yet. And it's not even an official feature! 😛
In LabVIEW 2013 or later, add the following token to your INI file:
QuickBold=True
Now, whenever you are editing text on the front panel or block diagram of a VI, Ctrl-B will bold/unbold text:
If you want this (or more generally, all standard font-editing keyboard shortcuts) to become an official LabVIEW feature, please go here and kudo the idea!
Message 1 of 27
(14,266 Views)
Only catch is that I usually need to remove broken wires much more often than I need to embolden text...
So here's my current thinking:
Remap Ctrl+U to "Remove Broken Wires", because I don't much fancy the "Clean Up Diagram" tool anyway... Then Ctrl+B is ripe for the picking! (I wonder how long my muscle memory will take to readjust...)
Message 2 of 27
(14,194 Views)
QuickBold is only activated while you're editing a text field. If you're not editing a text field, Ctrl-B will remove broken wires as usual.
Message 3 of 27
(14,191 Views)
Oh... wow! That feels much better.
I hereby double my kudos.
Message 4 of 27
(14,184 Views)
So then why do we have to add a ini key to enable this feature? Just curious...
Message 5 of 27
(14,139 Views)
As Darren said, it hasn't officially been released yet.  I believe NI just wants enough people to play with it before it is official, just in case there is a severe bug.  I would assume that once it is official that the ini token won't be necessary.
GCentral
Message 6 of 27
(14,104 Views)
Wow, after four years, they finally implemented it!
Darren, thanks for sharing this info.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 7 of 27
(14,069 Views)
Love it.  Saw it at NI Week and have been using it ever since.  As I suggested at NI Week this function should be supported in the VI Documentation editor as well.  Even if it is something simple like adding the <b> and </b> tags into the string when CTRL+B is detected.
Message 8 of 27
(14,055 Views)
Thanks for that Darren!
Now you know I've GOT to ask does QuickHyperlink or QuickBookmark work?
On second thought make that QuickHyperlink- No one really uses revision history but Help is fairly useful
"Should be" isn't "Is" -Jay
Message 9 of 27
(14,024 Views)
I can't help you with QuickHyperlink yet, but we've already got QuickBookmark in 2013...it's Shift-3. 😉
Message 10 of 27
(13,991 Views)
