Data channel switch in FPGA application
Hi, I add your quotient & Remainder selection to " the number of elements to read ". I found the channel constantly switched to the previous one ( like AI1 goes to AI0), even if I connected the right channel in hardware. So I can now save the data as it switched and do the post processing later. However, I still have no idea why it becomes switched.  The problem was solved in an unexpected way. But I really apreciate your help! Thank you1
Message 11 of 18
(1,199 Views)
yes you are right!
Message 12 of 18
(1,199 Views)
Message 13 of 18
(1,174 Views)
Actually I've the same problem, in the RT side when I plot them they shift one position, for example: I see the data of channel 1 in graph for channel 2, etc.
Message 14 of 18
(1,169 Views)
@bjoa wrote:
That's not what I was pointing out.  Certainly, I understand taking N Chan number of samples out of a buffer.  Quotient and remainder is your friend in that!
I merely pointed out the ridiculousness of changing the logic when the remainder is zero.  Work it through as a mental exercizeSmiley Wink  samples avaiable - 0 is equal to samples available minus remainder ONLY when Remainder = 0 and both inputs to select are equall to each other!  The selection criterea is Remainder Not equal to 0.
So just read samples available  minus samples available mod n remainder
"Should be" isn't "Is" -Jay
Message 15 of 18
(1,130 Views)
Hi all,
I had the same problem, and was able to solve it this morning thanks to the Labview engineers. I added the FIFO reset to my software on the host side and it has stopped the channel switching errors. Because the FIFO Reset does not work in simulation mode, I removed it a long time ago, and therefore forgot to add the Reset when it was time to execute on the target. The Reset worked for me, so just add it in once you are ready to execute your software on the FPGA target. I hope it works! I have attached two images on how to set up the Host and Target DMAs, and also how to clear the FIFO using FIFO reset.
These VIs were provided by tech support! Also, the software seemed to stop switching when using the case structure on the host side (see pictures); I found that the software did not stop the channel switching with the remainder technique.
Zee
Message 16 of 18
(1,098 Views)
Jeff·Þ·Bohrer
Got it, I didn't see your point, you are right.
Message 17 of 18
(1,073 Views)
@bjoa wrote:
@JÞB
It happens that occasionally I am right,  It usually supprises my wife too when that happensSmiley Very Happy
Message 18 of 18
(1,046 Views)
