Data recording excel or text file
If I use a write to spreadsheet.vi, can i write strings like the label/caption to the spreadsheet.
I tried to use the property node to extract the label, but I am not sure how I can use it with the write to spreadsheet.vi
Message 11 of 12
(379 Views)
The extracted data should be a string, in which case a string is an excepted input for the write to spreadsheet file VI.  Here is some more information on the write to spreadsheet file vi:
http://zone.ni.com/reference/en-XX/help/371361J-01/glang/write_to_spreadsheet_file/
In this case, go to the section about writing strings.
If you are new to LabVIEW, the page below may help you find resources for training and tutorials:
http://www.ni.com/labview/skills-guide/en/
Jon F.
Technical Support Engineer
Message 12 of 12
(364 Views)
