10-07-2015 05:23 AM
Hello Everybody,
I have an DAQ wich measured 4 values on 4 Channels.
However, the resulting string is converted into an array (ASCII) - via Match Pattern.
Til now, everything is fine.
After that in converted the array (ASCII) into an array (numeric) - via Scan from String.
The problem is that i lost the decimal places in the numeric array. (as in the pictures)
Could anybody help how i get the decimel places into my numeric array?
(the programe is in the attachement)
Cheers,
Marcs
10-07-2015 05:39 AM - edited 10-07-2015 05:41 AM
Hi Marc,
The problem is the decimal separator you are using in your (German?) Windows regional settings!
Either switch your PC to use English settings (as I recommend my users) or use a better format string to convert from string to numeric - LabVIEW help lists all of them and explains them!
The 3rd option is to switch LabVIEW behaviour in the LabVIEW settings - but that might produce errors once you create EXEs or move VIs to a different computer…
10-07-2015 06:19 AM
Yes indeed. Thank you very much.
