Decoration labels
If I show a decoration's Object Property dialog, a field named "Label" appears where I can type text in (LV2011). There's also a "Visible" check box above it.
However, the check box keeps to be disabled even if I put some text in the label, furthermore the text is not retained when I close the dialog.
On the other side, a decoration property node will not show any "Label" item.
What this field is good for?
Paolo
Message 1 of 14
(6,844 Views)
Probably nothing. The Decoration class, if memory serves, inherits from Generic, which does not have a Label property. I'm guessing this is just an oversight in the dialog where no one thought to hide that field. I didn't even notice that you can open the properties dialog for a decoration.
___________________
Try to take over the world!
Message 2 of 14
(6,839 Views)
That's a pity. I did hope to use that Label to identify decorations. Indexing the Decorations[] array it's uncomfortable and prone to errors.
Paolo
Message 3 of 14
(6,834 Views)
Accepted by pincpanter
  1. Vote for this idea - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Explicit-Decoration-References-to-LabVIEW/idi-p/97...
  2. Use this RCF plugin (or adapt it to be a QD shortcut) - https://decibel.ni.com/content/docs/DOC-6496
___________________
Message 4 of 14
(6,805 Views)
Thanks for the links. In the meantime, I have written a "decoration managing" vi that may be useful to show decoration indexes and easily hide/show them.
BTW: for a label decoration the Label field matches the decoration text.
Paolo
Message 5 of 14
(6,770 Views)
Just put a floating label next to the decoration, then group them.
Message 6 of 14
(6,754 Views)
What I would like to do is to show/hide and possibly move decoration programmatically. For this, I need to know the position (index) of each decoration in the Decorations[] reference array.
That index may change when you move objects forward or backward in the FP. Hence the need of a method to find the index quickly.
Paolo
Message 7 of 14
(6,735 Views)
I would assume the index doesn't change, but i haven't tested it. Z-property doesn't change index of controls, to my knowledge, only tab-order.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 14
(6,730 Views)
/Y
The index does change indeed following the Z order. You may check it quickly using my vi.
Paolo
Message 9 of 14
(6,727 Views)
Hmm, what if you turn the decoration references to Variants and add use Set Attribute? Then you have something to search for.
/Y
Qestit Systems
Message 10 of 14
(6,720 Views)
